Invalid client_id error when trying to add a map to the application
529
09-06-2021 03:59 AM
KristianTuusjärvi
New Contributor II
I'm trying to add a web map that I have in my arcgis online to Experience Builder's map widget. The web map works fine in the online map viewer, but it gives this error when trying to add into Experience Builder.
Within the Web Map I have a feature layer that is from aineistot.esri.fi which requires different credentials. I suspect that this feature layer is causing the issue. However, I do not know what to do about it?
CourtneyMenikheim
Have you tried creating an item in your ArcGIS Org for the feature layer with stored credentials, and adding that to the map instead?
Do you get this error with any other maps?
Courtney Menikheim | Application Developer | @thecmenikheim
