How to remove attachments from Edit widget when editting existing feature
1278
07-21-2022 06:35 PM
Lindsay
Hi ExB Community,
I noticed that when I use the edit widget and use the select function to edit an existing feature, attachments shows in the form. I've removed attachments from the pop-up via Map Viewer.
Is there a way to prevent this from happening? I don't see attachments when I click in the map and the pop-up shows. I don't see attachments when I create a new feature.
Thanks in advance for your help.
TianWen
The attachment part shows as long as the service support adding attachment. We'll consider an enhancement to allow showing/hiding the part. Thanks for the post!
