How to change the default dock position of a popup window in ArcGIS Experience Builder
78
13 hours ago
SanchezNuñez
Good afternoon,
Is there a way to change the default dock position of a popup window in ArcGIS Experience Builder?
It always shows on the top right of the map.
Thank you.
JeffreyThompson2
MVP Frequent Contributor
Yes. In the Map Widget Settings Panel, expand the Options submenu with Dock The Pop-up selected set the Position to Custom and click the box you want to move it to.
GIS Developer
City of Arlington, Texas
JeffreyThompson2
GIS Developer
ClioClark
Hi @SanchezNuñez,
In the Map widget settings, you can either have pop-ups appear at the default position or switch to Custom and choose one of 6 docking locations within the frame of the Map widget:
Please note that to configure this, you must enable the 'Dock the pop-up' setting, which will always dock the pop-up when opened. However, users can still undock the pop-up once opened.
Please see the following documentation for more information: https://doc.arcgis.com/en/experience-builder/latest/configure-widgets/map-widget.htm#:~:text=Positio....
Hope this helps!
