How to attach images from a field containing the path on a server
2035
07-17-2023 07:04 AM
pbDudley
Hello
I have features that contain a hyperlink field that in the old versions of arcmap, one could use the hyperlink tool and the image/pdf would open
Now I am trying to use these same links in portal. I see where it lets one select a url path but it wont let me add a path pointed on the server?
Also, it appears that if I did have the option to point to file location(which some of the apps allow) one can only do this manually, where each would have to be clicked on and pointed to the image file.
Is there a way to use a field in a feature that works as the old hyperlink tool did or does one have to manually click and navigate to each to get the hyperlinks to work?
Thanks
jcarlson
Where is the link directed to? It sounds sort of like they might be files in a network folder?
It's not a "tool", it's just a link. Those same links would work fine in ArcGIS Pro, but not in Portal / AGOL. The difference is that when you are working in desktop software, a file path is something the program understands. In Portal, there's no guarantee that the client has access to items at file:///some-location, so Portal automatically scrubs any links that aren't HTTPS.
If these URLs actually are web-accessible files, you can add image elements to the popup and pipe in fields to define the images source URL.
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
pbDudley
Alright thank you
Thats what I thought. The paths are file based and not to a url
I did see that I can navigate to each of the file locations and attach the pdf/tifs that way. I just have a lot of these to do so was checking to see if there was a way. But I understand your answer. Thanks
jcarlson
Now, if you wanted to actually add these as attachments, Python can make that pretty easy. There's an attachment manager class that you can use to add the files, using the feature's filepath field to locate the file. I have a script somewhere that does that, and I could dig it up if you like.
- Josh Carlson
Kendall County GIS
pbDudley
Well yes thank you. If you can find the python script I would try it out for my workflow. Thank you
