Filter Widget Icon Color
351
6
09-05-2025 01:08 PM
JenniferBorlick
I add custom icons to my filter widget in white. I could have sworn that I read something somewhere that if you do that, it would take on the color of the text if it was changed.
I'm changing the color scheme, and that is not what is happening. They are staying white.
Is there a setting I missed somewhere? Did I misremember?
Or alternatively is there a way to change the filter color background and text IN the filters? The only thing I have found is to change the background the filters sit on. I have to be missing something. Right?
RoryMcPherson
Hi @JenniferBorlick, you're not able to change the colour of custom icons you upload to ArcGIS Experience Builder. If you want to use your own custom icons, I would suggest deciding on a colour scheme you want to use, and then changing the colour of your icons to suit that scheme before uploading them.
RoryMcPherson
JeffreyThompson2
MVP Frequent Contributor
https://community.esri.com/t5/experience-builder-tips-and-tricks/changing-the-icons-and-titles-of-wi...
You can change the color of the built in icons. It doesn't look like it's possible to change the colors of icons you upload. As @RoryMcPherson said your best option would be to colour your icons before upload.
GIS Developer
City of Arlington, Texas
JenniferBorlick
Of course, now I can't find any of the blogs that I was using when I created this thing in the first place to see what I was doing to make it. I remember thinking that I should make them all in white in case I wanted to change the theme because that was what the tip said to do... Then again, memory is fluid.
I thought I had the theme that I wanted to use, but... long story short, it didn't work the way I wanted in the end. So I reset back to default and started over.
My original looked like this:
I had started in the dark theme. I think that's why the filters are dark because I can't figure out how to change the ones in the current app.
JenniferBorlick
Much Better
vic7oria
As these icons seem to be your own uploads. You will need to update the color individually and readd them. I googled and found a tool to do this for myself last year. I will add it below, but if it isn't the best fit for you I recommend doing your own search, there are some free ones out there.
https://onlinepngtools.com/change-png-color
JenniferBorlick
@vic7oria I will add that to my toolbox. Thanks.
