Expression to count the number of features where a condition is true.
4307
10-13-2022 08:14 PM
GregReinecke
In ExB I'd like to count the number of features where the condition met is true. I have a number of features with a text field called "Is an Issue Flagged?". If the value is "Yes" (i.e True) then I'd like to count them. So if I have 6 features with the field   Is an Issue Flagged  = "Yes"   I'd put a 6 in a dynamic text box.
Here is my expression that doesn't work:    IF {Is an Issue Flagged?} = "Yes" THEN  COUNT({ObjectID}) END
Thanks in advance.
GR
WFNSProject
The approach is likely not an arcade solution but the approach you presented is perfect. I did actually use views in ExB and  counted items from there. I was just trying to skip that step. Thanks you.
Kara_Shindle
Where is this calculation in the experience?  If you are able to use Arcade, I saw this Geonet response that filtered by the field and I think you could do something similar.
https://community.esri.com/t5/arcgis-online-questions/arcade-totaling-field-values-of-features-conta...
alternatively,
var fc = FeatureSetBYName($datastore, "layername", ["Is an issue flagged"], True);
var cnt = 0;
for (var yes in fc) {
    if (yes.is an issue lagged == "yes")  {
        cnt += 1;
return cnt;
I based the above off of a solution here: https://community.esri.com/t5/arcgis-pro-questions/attribute-rule-arcade-filter-function-issue/td-p/...
WFNSProject
jcarlson
ExB doesn't have much in terms of expressions. Certainly not conditional statements. Data source views are (currently) the only way to accomplish this.
- Josh Carlson
Kendall County GIS
ShengdiZhang
Hi @GregReinecke ,
This feature is supported in the June 2025 AGOL release. You can now add an Arcade expression to the text widget.
Regards,
Shengdi
