EB requires always to Sign-in in AGOL when clicking on a link to an EB viewer
493
01-15-2025 07:28 AM
JoseSanchez
Good morning.
Is there a way for an end user to avoid to Sign-In when opening a viewer in AGOL?
We are using "'Your ArcGIS organization's URL.' as default to login.
Laura
by MVP Regular Contributor
Unless it's public, if you are not already signed in you will have to sign in to view it.
clt_cabq
You could try and implement some sort of single sign on (SSO) that uses your organizations active directory or other system to aid in logging in - this helps people keep their credentials they have to remember to a minimum, but it won't necessarily remove the sign in requirement for non-public facing content, just simplifies the process.
