Developer edition offline install
6512
10
04-16-2020 06:18 PM
LeonAus
I'm getting an error when trying to start the developer edition after following Jianxia Song's instructions of:
'The workaround we have is to get the modules from another place that has the internet installed, then copy the node module folder over to your environment without the internet. Keep in mind, the node version from both places should be the same. Otherwise, you may run into problems. Hope this helps.'
The node version is the same on the workstation where I downloaded the modules and where I am trying to run.
The error is:
D:\eGIS\Working\Leon\egis_dev\ExperienceBuilder_1.0\server>npm start
> [email protected] start D:\eGIS\Working\Leon\egis_dev\ExperienceBuilder_1.0\server
> cross-env NODE_ENV=production node src/server
internal/modules/cjs/loader.js:800
throw err;
Error: Cannot find module '../../global'
Require stack:
- D:\eGIS\Working\Leon\egis_dev\ExperienceBuilder_1.0\server\node_modules\exb-history-404\index.js
- D:\eGIS\Working\Leon\egis_dev\ExperienceBuilder_1.0\server\src\server.js
←[90m at Module._resolveFilename (internal/modules/cjs/loader.js:797:15)←[39m
at Function.Module._resolveFilename (D:\eGIS\Working\Leon\egis_dev\ExperienceBuilder_1.0\server\node_modules\←[4mexb-ssr←[24m\index.js:1:9904)
←[90m at Function.Module._load (internal/modules/cjs/loader.js:690:27)←[39m
←[90m at Module.require (internal/modules/cjs/loader.js:852:19)←[39m
←[90m at require (internal/modules/cjs/helpers.js:74:18)←[39m
at Object.<anonymous> (D:\eGIS\Working\Leon\egis_dev\ExperienceBuilder_1.0\server\node_modules\←[4mexb-history-404←[24m\index.js:1:2289)
←[90m at Module._compile (internal/modules/cjs/loader.js:959:30)←[39m
←[90m at Object.Module._extensions..js (internal/modules/cjs/loader.js:995:10)←[39m
←[90m at Module.load (internal/modules/cjs/loader.js:815:32)←[39m
←[90m at Function.Module._load (internal/modules/cjs/loader.js:727:14)←[39m {
code: ←[32m'MODULE_NOT_FOUND'←[39m,
requireStack: [
←[32m'D:\\eGIS\\Working\\Leon\\egis_dev\\ExperienceBuilder_1.0\\server\\node_modules\\exb-history-404\\index.js'←[39m,
←[32m'D:\\eGIS\\Working\\Leon\\egis_dev\\ExperienceBuilder_1.0\\server\\src\\server.js'←[39m
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] start: `cross-env NODE_ENV=production node src/server`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! C:\Users\vyXXXX\AppData\Roaming\npm-cache\_logs\2020-04-17T01_05_37_572Z-debug.log
The debug log file reports:
0 info it worked if it ends with ok
1 verbose cli [
1 verbose cli 'C:\\Program Files\\nodejs\\node.exe',
1 verbose cli 'C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js',
1 verbose cli 'start'
1 verbose cli ]
2 info using [email protected]
3 info using [email protected]
4 verbose run-script [ 'prestart', 'start', 'poststart' ]
5 info lifecycle [email protected]~prestart: [email protected]
6 info lifecycle [email protected]~start: [email protected]
7 verbose lifecycle [email protected]~start: unsafe-perm in lifecycle true
8 verbose lifecycle [email protected]~start: PATH: C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin;D:\eGIS\Working\Leon\egis_dev\ExperienceBuilder_1.0\server\node_modules\.bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\Git\cmd;E:\ArcGIS\Pro\bin\Python\envs\arcgispro-py3;C:\Program Files\nodejs\;C:\Users\vyXXXX\AppData\Roaming\npm
9 verbose lifecycle [email protected]~start: CWD: D:\eGIS\Working\Leon\egis_dev\ExperienceBuilder_1.0\server
10 silly lifecycle [email protected]~start: Args: [ '/d /s /c', 'cross-env NODE_ENV=production node src/server' ]
11 silly lifecycle [email protected]~start: Returned: code: 1 signal: null
12 info lifecycle [email protected]~start: Failed to exec start script
13 verbose stack Error: [email protected] start: `cross-env NODE_ENV=production node src/server`
13 verbose stack Exit status 1
13 verbose stack at EventEmitter.<anonymous> (C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\index.js:332:16)
13 verbose stack at EventEmitter.emit (events.js:210:5)
13 verbose stack at ChildProcess.<anonymous> (C:\Program Files\nodejs\node_modules\npm\node_modules\npm-lifecycle\lib\spawn.js:55:14)
13 verbose stack at ChildProcess.emit (events.js:210:5)
13 verbose stack at maybeClose (internal/child_process.js:1021:16)
13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:283:5)
14 verbose pkgid [email protected]
15 verbose cwd D:\eGIS\Working\Leon\egis_dev\ExperienceBuilder_1.0\server
16 verbose Windows_NT 6.3.9600
17 verbose argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "start"
18 verbose node v12.13.1
19 verbose npm v6.12.1
20 error code ELIFECYCLE
21 error errno 1
22 error [email protected] start: `cross-env NODE_ENV=production node src/server`
22 error Exit status 1
23 error Failed at the [email protected] start script.
23 error This is probably not a problem with npm. There is likely additional logging output above.
24 verbose exit [ 1, true ]
Any ideas what I'm doing wrong?
Thanks.
Jianxia
Junhan Liu‌ could you take a look?
JunshanLiu
I tried some ways but don't find a way to install successfully.
I'll create an issue in our repo to try to figure out a way.
LeonAus
Is there a rough time frame for when this will be resolved? Is it being looked at now or has it been deferred?
Leon.
Jianxia
Leon,
We plan to fix it in the upcoming release in July. Thanks for being patient with us.
JoeHershman
I found that running:
npm set strict-ssl false
Resolved the issue
-Joe
Jianxia
Wow, that's awesome. Thanks for sharing.
dumpetisrinivas
hi is this issue fixed in the Exb version v 1.14..? I'm installing in offline and getting cross-env module not found ?
JoeHershman
Is there a solution to this?  I have run as admin which does not make any difference.  Run from node.js prompt and standard command prompt.
Tried this: node.js - Laravel 5.4 ‘cross-env’ Is Not Recognized as an Internal or External Command - Stack Overf...
still no luck.  Why cannot I not run?
-Joe
-Joe
Jianxia
Joe,
We are looking into the solution.
