Change color of search-widget icon
2970
12-30-2022 06:13 AM
AndreasEugster
Is there a way to change the search-widget search-icon-color and background color?
By default the search-widget takes the color from the design-theme. Changing the design will update the background color of the widget. I have a usecase where the search-icon-background should be white and the magnifier icon black.
Challenge 1: Only that specific search-icon background color, not every other widget in the experience which uses the "primary-theme-color"...
Challenge 2: the theme changes only the background of the search-widget-icon. The color of the magnifier is not affectet and stays always white, making it disappear if the background-color is white too...
Any ideas?
- Andi
DaveFullerton
Please support the idea about this issue that I posted here: https://community.esri.com/t5/arcgis-experience-builder-ideas/search-widget-add-style-settings-for-t...
Adding a comment about why this is important for your organization and how many people it effects would further help push this along.
AndreasEugster
I'll support the idea asap.
In the meantime, the workaround: After downloading the app, manipulate the widget.js file by adding the color and background-color to the .search-button.
...\cdn\0\widgets\common\search\dist\runtime\widget.js
.search-button {
	width: ${n.polished.rem(32)};
	border-radius: 0;
	color: #4678B4;
	background-color: white;
VictoriaDavis1
Changing the primary theme color should be what you're looking for
AndreasEugster
...make the primary color white to see the issue 🙂
