Bookmarks in a droplist
503
07-05-2024 09:05 AM
KevinMayall
Any ideas for implementing bookmarks in a droplist?  I wanted to tuck the bookmarks away in a header bar, in a droplist type widget, and then have the map widget zoom to the bookmark accordingly.  As opposed to having a full list of bookmarks visible in the bookmark widget, taking up space on the interface.
Kevin
JeffreyThompson2
MVP Frequent Contributor
Using the Advanced or List Templates in the Bookmarks Widget, it is possible to make a vertically laid out set of bookmarks that is just a name or name with an icon. Then you could use the following trick to make a dropdown menu. I think it should technically work. I'm not sure you will be able to make it look good.
https://community.esri.com/t5/experience-builder-tips-and-tricks/making-a-dropdown-menu-out-of-a-sid...
Edit: Re-reading your post. A much simpler option would be to place the Bookmarks Widget in a Widget Controller. This will likely look better as well.
GIS Developer
City of Arlington, Texas
