Blank Map versus Monitor Templates Performance
2787
10
07-23-2021 07:28 PM
RodWoodfordOld
Hi Is there a rendering performance issue with the map widget when rendering the same scene map in the Blank Full Screen template and the Monitor template. We are finding the Monitor templates map widget does not render all layers (3d building, trees, etc) in a scene map completely within it extent whereas the Blank Fullscreen templates map widget extent renders all layers quickly . I have tested this with the same scene map. Can you please elaborate? See test links below
Sample Blank screen App
https://experience.arcgis.com/experience/dba404cbe2954c74a430ba50a067c7ba
Sample Monitor App
https://experience.arcgis.com/experience/6f721e1f606f4dd5b94e1d59dd4afeca
Any advice would be useful.
RodWoodfordOld
Hi Jonathan,
Now that the map is not displaying all content within its view, does this mean the chart information is also not correct? I think ESRI need to look at this rendering issue as it has the potetnital to provide misleading information.
cheers
