Best way to view related record in Experience
18695
18
11-17-2021 11:17 AM
Boyang_Wang
Hi
I am working on an app that shows related records of a selected record. In Web AppBuilder there are several ways to show related records. One is on the popup, one is in Query widget, and one is in Attribute Table widget.
However, in Experience I do not see a way to show related records. Even the popup does not have "related table" option like in Web AppBuilder. I think it has to do with the difference between classic Map Viewer and new Map Viewer? I am not familiar the new Map Viewer as it is not available in my Enterprise Portal. What are the alternative ways to show related records in Experience?
Thanks!
bsanders69
This seems all well and good, but it still does not use the existing relationship classes already built for maintaining the relationships.  This used to work in the old Viewer (classic), but not in the new one.  Relationships are everywhere.  It is the 'R' in RDBMS. Most of your solutions have relationships.  My example would be Street Signs and their support structure (Poles).  A Pole has 1 to several signs.  In order to use Field Maps or Collector even, I have to stay in the Classic Map Viewer version in order to add the Signs to the poles in the field or in the web map.
ZachBodenner
MVP Regular Contributor
Agreed, I have the same thing with signs (and many others). This is a pretty big deal if New Map Viewer is the default going forward.
Happy mapping,
- Zach
TiiuKelviste
We are having exactly the same issue. Work with the feature class but not with the related table (showing no data).
TiiuKelviste
I tested the same workflow in ArcGIS Enterprise 10.9.1 EB version and it worked fine there, but it is very old in terms of other apps and functionality available today in ArcGIS Online.
Boyang_Wang
I just learned that Web AppBuilder is considered deprecated, while there is still no way to deal with Relationship established in published Feature Service in Experience. Am I missing something here?
Also, I just realized that, in ArcGIS Online Map Viewer, I cannot see related records for Feature Service hosted in my ArcGIS Enterprise 10.9. Does ArcGIS Online Map Viewer only supports relationship in Feature Services hosted in ArcGIS Online? What about the Map Viewer in Enterprise if I upgrade it to 11.1?
ZachBodenner
It's creeping its way back in: https://www.esri.com/arcgis-blog/products/experience-builder/announcements/whats-new-in-arcgis-exper...
Still can't do it in the web map with non-hosted layers.
Happy mapping,
- Zach
KateDoughty1
Has there been any other solution to showing related records? The issue with setting it up this way is that a selection is required to filter the data - but I'm using the Filter widget, so the map is filtered but the related table is not.
Service_SIG_CAPDFT
Hello,
you have to publish your data with related table on 11.2 enterprise to get the natives function (see https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/rolling-out-related-records-in-map-v...).
In my case i have an old 10.9 enterprise. So I had to use the list widget on related table and the filter action on the map widget (from main class to related table) to get something usable.
Boyang_Wang
This is good to know! Is this outlined in any ESRI document? I am urging my organization to upgrade our Enterpirse 10.9 and this can be a good argument.
