ArcGIS Experience Builder calls to BackEnd services
394
06-28-2022 06:22 AM
EsriTG
New Contributor II
A customer of ours is analyzing “ArcGIS Experience Builder” as a new software to use instead of the Web AppBuilder to create the Geographic Viewers.By carrying out some tests, the customer cannot understand how a BackEnd service can be invoked from a widget (with a different domain, therefore with CORS problems) which can be used, for example, to send an email or have some information returned to make analyses.With the Web AppBuilder the calls were "proxed" through a JSP page (proxy.jsp) that bypassed the CORS problem, but with Experience Builder what is the correct mode?They also used the proxy.jsp for authentication to protected services, now what is the procedure to follow? Thank you
