Like to have choose the spatial filter layer the same layer as the attribute query layer. It is very important for our user. We need find parcel attribute with the parcel id, also need to do the spatial filter for the surround parcels , for instance the intersect the parcels within the 500 feet buffer around the selected parcel
The Query Widget supports spatial buffers. This video will show you how to set one up. https://youtu.be/8C9DNPupK2k?si=NFnqD51qQOt49rvw
I'd like to let the buffer stay on the map as graphic layer which user see the buffer and print out the map
