Currently in the Filter widget, the 'contains' operator only returns features where a given field contains all selected values.
I would like to see an operator that would return features where a given field contains any of the selected records.
For example, with a field containing a list of values:
ObjectID | Land_Use |
1 | agricultural, industrial |
2 | residential, agricultural |
3 | educational |
4 | recreational, industrial, residential |
Land_Use contains any of agricultural, industrial
would return features 1, 2, and 4.
Hi Tara,
You can use clause set to do this:
Please make sure you use "OR" for the use of contains any of.
Shengdi
Hello Tara,
Thanks for your feedback and we appreciate that you brought this up!
We are considering the function of predefined values for the next releases. Once it is implemented, you can use the function of contains > Multiple (predefined) to achieve your goal here. Before that, you can use Shengdi's comment as a workaround.
Best,
Tonghui
