Near Me Separate Distances per Analysis
339
11-06-2024 06:19 AM
Status: Open
JBH
It would be nice to be able to set separate search distances per analysis layer in the Near Me widget. Right now, if we add multiple analysis features, the search distance is going to be the same for all of them. The workaround is to add multiple Near Me widgets with different search distances and string them to run together through a Select widget, which is a bit tedious.
We use the tool for Planning purposes and so most of our analysis do not require identical search distances.
1 Comment
JeffreyThompson2
https://community.esri.com/t5/experience-builder-tips-and-tricks/using-near-me-without-looking-at-ne...
If you don't need to use the controls within Near Me for your workflow, you may be able to use multiple hidden Near Me Widgets and output the results to a Feature Info Widget.
