Map Widget:
Map Layers widget:
The data sources can be managed on the left-side panel under the Data tab. You can go there and delete the unwanted ones.
The issue with Bookmark layers has been fixed and it should not show in the list in Map Layers or the map tool anymore. You can give it another try.
