Often times when creating graphical applications or layouts of any sort, you reuse elements to save yourself the time. One point of frustration with this in EB is that it clears the formatting of your text box if you select the text and type over it. The workaround is a little fussy, you have to type your new text in the same box with the old text and then delete the old text -- not ideal nor intuitive. The box should retain the formatting of the text being replaced.
