ArcGIS Experience Builder Blog
316
3.6M
79
Open | Attribute Expressions in Map Viewer are incredibly powerful and extremely useful. Unfortunately, bringing those wonde... by JonathonMerrick New Contributor III 9 0 | 9 | 0 | |
Open | Experience Builder cannot support related data and so cannot support relational databases, the most common type of da... by USArmyCorpsEngineers New Contributor II 13 2 | 13 | 2 | |
Open | This is kind of a big request so I'll do my best to explain: If I have an experience that I've spent a good long whil... by ZachBodenner MVP Regular Contributor 4 4 | 4 | 4 | |
Open | There is a frequent need to dynamically output an average value of one field in relation to the other when filters or... by IgorAtamanchuk New Contributor III 4 1 | 4 | 1 | |
Open | Currently, the Map View Widget only works with Web Maps and Web Scene services. It would be great to be able to add ... by EricMahaffey1 Occasional Contributor 2 0 | 2 | 0 | |
Open | Please provide links to broken layers in Experience Builder and other web apps. Links to the Feature Layer source on... by Levon_H New Contributor III 0 0 | 0 | 0 | |
Open | Allow for the full list of Arcade or SQL mathematical functions when building an expression, including things like SQ... by JeffreyEngstrom New Contributor III 5 2 | 5 | 2 | |
Open | Has anyone attempted to code a GTX2EXB Geocortex Essential 4.12-4.15 to WebMap&Experience Builder project?The idea wo... by fpolia21 New Contributor II 0 0 | 0 | 0 | |
Open | Provide a URL parameter format to launch an Experience with a feature selected by globalID for editing. This is an aw... by Will_CulturalFire New Contributor III 0 2 | 0 | 2 | |
Open | We need a new "open map/scene" widget similar to what the Atlas instant app has. by BrandonGuo Occasional Contributor 0 0 | 0 | 0 | |
Open | It would be extremely helpful if Esri created the option to select multiple Source layers that could be used to send ... by DaveKnauer New Contributor II 6 1 | 6 | 1 | |
Open | In the DataSources tab, users have the ability to query a selection of layers or records from layers to use as filter... by PaulinaMarczak New Contributor III 5 0 | 5 | 0 | |
Open | Utilising Experience Builder as a more complex/controlled environment to story maps. The goal is to add videos into e... by Corinna_Gosby New Contributor II 13 0 | 13 | 0 | |
Open | As it is now possible to time-enable Scene Layers: could you extend the possible data sources for the Time Line widge... by 3DMS New Contributor II 7 0 | 7 | 0 | |
Open | The "Add Data" widget in Experience Builder needs better design compared to the new Atlas Instant App. Three key issu... by BrandonGuo Occasional Contributor 5 1 | 5 | 1 |
Idea Submission Guidelines
User | Count |
20 | |
16 | |
14 | |
14 | |
12 |
