The Filter widget only displays values in alphabetical / alphanumerical order. When i add predefined values (using the SQL Generator) i can add values in a particular order but the filter widget does not keep those values in the specified order. It would be very helpful if the Filter widget could be enhanced to keep the order of values in the filter according to the arrangement i set in the generator.
If you manually enter predefine values, Exb gives you a nice option to order them any way you want.
Unfortunately, that order is ignored, when the app is published.
Posting my use case. Need to order based on Pavement Condition Index order, not alphabetical. I wish the defined value order would stick.
Same issue here. Please get this fixed.
