A limitation I have come across, I cannot create multiple connections in the survey widget within experience builder to multiple features. Multiple connections can be made to one feature, however you cannot create one connection to multiple features. Limits to one feature with connections at a time.
I agree. The article suggests that data from different sources can be used but you can only create a connection to a single source. Additionally, only a single feature copies, even when multiple features are selected. So, although the only data I have configured to connect is the spatial data, only one feature copies. Ex: select multiple counties or states, only one of them is added to the survey.
