Hello Experience Builder Team,
Please create a way to manage field requirements through the Edit Widget. Currently there is no way to make fields required/not required. This will allow admins to ensure data quality.
EB Edit Widget Field Configuration- There is no way to make certain fields required:
Thank you,
Amanda Huber
Please! The "created" feature currently disappears (doesn't create) without warning if not all fields are filled out, and instructing users to add placeholder data messes with SQL queries and views already created and in use elsewhere.
Additionally, date fields require a time even when it is turned off in the pop-up.
We have 10.8.1 Enterprise and are still using the old web map. No matter what I do in the fields configuration it makes no difference. I just suspect the old web map is the cause. Hoping 10.9.1 upgrade will fix this.
Compulsory fields and maybe some of the Field Maps functionality with semi-smart forms would be good.
Why would I want to edit ObjectID?!?! 🤔 👇
