I would like to execute an AGOL Notebook from the Experience Builder Button Widget. I have AGOL Notebooks that I use to trace content in my portal. For example, one script can take a Web Map ID and find a Web Application that is using that Web Map. It returns the results in a print statement and as csv in my account.
I would like to be able to call the script and execute it from a button in experience builder.
The closest thing I've found to being able to do this is by creating a dashboard, embedding my experience builder app in the dashboard and also embedding the notebook in the dashboard. Then I can run my notebook directly in the dashboard. It's not the prettiest, but it's the only solution I've come up with thus far. I just allow elements to be resized in the dashboard and hide the notebook when the dashboard first launches. When I need to execute it I just expand the window and run. 🙂
Seconded.
There are some basic actions for data in Experience Builder but would be good to add one that can fire off a backend process i.e. Notebook.
So you would choose Add Action->Run Notebook->Select Notebook and choose an attribute from your datasource to use as a parameter OR if no param chosen, it just runs the Notebook.
This would be great to do, I have a number of scripts that currently run on scheduled tasks but I would like the user to be able to press a button and set the script running without having to give them visibility of the script.
