ArcGIS Experience Builder Blog
310
3.4M
75
Open | It would be great to have a widget in Experience Builder that would allow you to save a screenshot of the app interfa... by SterlingLoetz New Contributor III 0 0 | 0 | 0 | |
Open | I have an idea about using selected features in an analysis tool in Experience BuilderIf I use the select tool to sel... by LarsElmkær_Chwastek Occasional Contributor 1 0 | 1 | 0 | |
Open | In Experience Builder, rearranging items on the page requires dragging and dropping within the GUI. For example, if I... by ZachBodenner MVP Regular Contributor 3 0 | 3 | 0 | |
Open | In Experience Builder, disabling the Export data action is done on the data source. This has to be done on every sing... by Thomas1 Occasional Contributor 2 0 | 2 | 0 | |
Open | In a non-scrolling page you have the ability to put images directly next to each other in a row (no spaces between im... by DaisybLewis New Contributor II 1 0 | 1 | 0 | |
Open | Hi Esri, The near-me widget functionality is one that we can make good use of for a particular product in Experience ... by Sibe New Contributor II 0 1 | 0 | 1 | |
Open | It would be good to have the ability to customise the appearance of the Timeline widget (much like one can edit the ... by BronwenHughes New Contributor III 3 1 | 3 | 1 | |
Open | If there's no option to import Web AppBuilder apps into Experience Builder and no support for Web AppBuilder post its... by AbiDhakal Occasional Contributor III 3 0 | 3 | 0 | |
Open | In the very near future, Web AppBuilder is slated to be replaced by Experience Builder. To ensure a smooth transition... by AbiDhakal Occasional Contributor III 17 6 | 17 | 6 | |
Open | Any URL linking to a View should provide the option to automatically open the side panel containing it.here is mock-u... by FredericPoliart_EsriAU Occasional Contributor II 2 1 | 2 | 1 | |
Open | As recommended by ESRI I post my original Question as an Idea to improove the draw widget in ExB: Draw Widget: change... by DirkSilbermann Occasional Contributor II 3 0 | 3 | 0 | |
Open | Experience Builder cannot support related data and so cannot support relational databases, the most common type of da... by USArmyCorpsEngineers New Contributor II 10 0 | 10 | 0 | |
Open | I would like this for a few reasons:- real estate of the map- users are most likely going to be making a brand new se... by Laura MVP 0 2 | 0 | 2 | |
Open | The New Batch Filtering via Groups is appreciated and well done. Thank You by ThomasRickett New Contributor III 0 0 | 0 | 0 | |
Open | This is kind of a big request so I'll do my best to explain: If I have an experience that I've spent a good long whil... by ZachBodenner MVP Regular Contributor 2 2 | 2 | 2 |
Idea Submission Guidelines
User | Count |
21 | |
17 | |
13 | |
13 | |
12 |
