ArcGIS Online Experience Builder - Select Tool
300
04-16-2026 08:03 PM
Status: Open
Labels (2)
AstridF
Is there a way to add to an existing selection using the Select widget in Experience Builder?
When I use the Select widget, I can’t add to the current selection — holding Shift doesn’t work. However, if I enable selection directly from the map’s own selection tools (instead of the widget), adding to the selection works as expected.
Is this a known limitation of the Select widget? Ideally, we’d like to use the Select widget only, without having to enable both the map selection tools and the widget controller.
Thanks!
3 Comments
Ke_Xu
by Esri Regular Contributor
AstridF
Hi! Thanks for the response. Would it be possible to include it as future improvement - adding to the current selection using the widget?
Cheers
A
Ke_Xu
Hi @AstridF,
We’ll consider this enhancement request. Could you help provide some specific use cases or application scenarios?
Ke
