Allow extent change triggers to rotate maps
279
09-14-2021 09:08 AM
Status: Open
VincentNg1
One of the interesting capabilities of Experience Builder is to show both 2D and 3D data at the same time.  Right now you can synchronize the extents of the two displays with a trigger for Extent Changes - Zoom To. However, with 3D data, users may rotate the scene to view data from other angles, and while the 2D map extent may change somewhat, it would be more ideal if the 2D map could rotate to have a similar orientation to the rotated 3D map.
