When I import annotation from AutoCAD to ArcGis10.4,the annotation is shown as points.
Because there is no check 'Label features in this layer' option?
But where is this option,I can't find from 选中图层(Layers)-->右键“属性”(properties)-->点击"Labels"选项卡(Lables),勾选"Label features in this layer" -->确定(Confirm)
Whether arcmap in arcgis10.4 compare with arcgis10.0,the option is different?
Where is it in arcgis10.4 ,on the 'display panel' 'field panel' or 'annotation panel'?
How can I make the annotation text of AutoCAD show on ArcGIs layer,not little point.
Did you try Import CAD Annotation ?
Using the Import CAD Annotation tool—Help | ArcGIS for Desktop
Cheng,
What you are seeing is the default behavior of CAD annotation.
One way of converting that CAD to geodatabase annotation is to right click on the layer and select "Convert to Geodatabase Annotation"
This step has done. How can I make the annotation text show on ArcGIs layer,not little point?
Are you trying to display annotations? http://desktop.arcgis.com/en/arcmap/latest/map/working-with-text/displaying-geodatabase-annotation.h...
