What license is required to perform spatial analyses by interpolate points tool in ArcGIS 10.5 with portal?
2404
06-06-2017 10:16 AM
CLEBEROLIVEIRA
New Contributor II
After running the tool through your JobID, it shows the following messages.
ERROR 000824: The tool is not licensed.
Failed to execute (EmpiricalBayesianKriging)
Installed software:
Portal for ArcGIS with web adaptor 10.5
ArcGIS GIS Server Standard 10.5 with Data Store and configured as Hosting Server do Portal
User Role: Administrator.
When I read this link:
Standard and GeoAnalytics Tools feature analysis comparison—Portal for ArcGIS (10.5) | ArcGIS Enterp...
I understood that ArcGIS GIS Server Standard was able to perform this type of analysis.
thanks in advance for your help
JianLange
To be able to run Interpolate Points, you need to have GeoStatistical Analyst for Server, which s included only with ArcGIS Enterprise Advanced.
JianLange
CLEBEROLIVEIRA
New Contributor II
Thanks for your information.
AnnMJ
Hi, I have the Advanced ArcGIS extension, but I still get the same error 000824. Do you mind helping me a little bit? Thx!
Here is my error:
"File "<ipython-input-11-d4f2fb910fb0>", line 34, in <module>
outKriging = arcpy.sa.Kriging(inFeatures, field, kModelOrdinary, cellSize, kRadius, outRaster)
File "F:\ArcGIS10.8\Desktop10.8\arcpy\arcpy\sa\Functions.py", line 2810, in Kriging
out_variance_prediction_raster)
File "F:\ArcGIS10.8\Desktop10.8\arcpy\arcpy\sa\Utils.py", line 53, in swapper
result = wrapper(*args, **kwargs)
File "F:\ArcGIS10.8\Desktop10.8\arcpy\arcpy\sa\Functions.py", line 2802, in Wrapper
File "F:\ArcGIS10.8\Desktop10.8\arcpy\arcpy\geoprocessing\_base.py", line 510, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
ExecuteError: Failed to execute. Parameters are not valid.
Failed to execute (Kriging)."
Here is my extension window:
mody_buchbinder
Occasional Contributor III
Try to run the tool in foreground (on the geoprocessing option menu there is an option for this).
It sometimes solve such a problem.
