What is the correct way to setup Citrix Netscaler with ArcGIS Enterprise base deployment for public access?
Here is my setting:
No surprise. All portal functions work fine if I use the internal URL within company network.
But for an external request using the public URL "https://gis.companyname.com/gisportal", that's a different story. It does show the portal home page correctly. I can navigate the portal without problem. Opening a feature/image layer or image layer does not work. The URL box in the layer description page shows the internal URL (something like https://servername.ad_domain.lcl/gisserver/...)
Travis S. from Esri pointed me to an Esri article "Configure your portal to use a reverse proxy server".
https://enterprise.arcgis.com/en/portal/latest/administer/windows/using-a-reverse-proxy-server-with-portal-for-arcgis.htm
I followed the instruction on the document,
After those changes, I'm still having the same issue with the portal from the Internet. I think the reason is the article is for Apache Reverse Proxy, not for Citrix Netscaler.
Anyway, our Netscaler guy came up with a workaround solution. First, he added a Netscaler policy that will replace the internal URL with the public URL on the page HEADER. He then added a second Netscaler policy that replaces the internal URL with the public URL on the page BODY. I'm able to access all ArcGIS portal contents from the Internet now. I'm able to add hosted feature layers and run analysis tools. (BTW, I removed WebContextURL changes from both the portal and the hosting server.)
Still, there are two issues:
I am able to save/update the same pages with the internal URL.
I can live with those two issues for now. But just want to know if there is a better way to set up reverse proxy on Netscaler for ArcGIS Portal. Any suggestion will be greatly appreciated. Thank you.
Luke
Hi, Did you open any support ticket and got some answer for this question or did you solve it your self?
Do you have anymore solution that you could share with me regarding netscaler configuration?
//Jonas
