What are Best Practices for Portal Administrator Accounts?
866
6
10-16-2024 06:09 AM
JonathanDandois
Our Portal is configured to use only SSO single sign-on for logins, and built-in user sign-ins are disabled. This has a nice benefit of allowing users to sign in to maps and apps quickly without having to think about clicking a sign-in option (for example, if built-in logins are enabled, users will try to enter their SSO credentials into the built-in field and it will fail).
I have my own personal SSO account enabled as a Portal Administrator. This allows me to quickly make changes to maps, apps, members, Groups, etc. However, a downside of this is that my user doesn't "see" maps and apps in the same way as normal users because of my Administrator Role. On more than one occasion, I have loaded a map/app and it works just fine, but standard users might see a layer permission issue or related problem.
Is it possible to use only SSO sign-in, but still be able to login as a built-in Administrator user? For example if I demote my personal SSO to a Publisher or similar role, but have a built-in Administrator user that i can use for Portal administration tasks?
BillFox
MVP Frequent Contributor
yes
BillFox
you can have both at the same time and disable the option for users to create their own internal portal accounts
JonathanDandois
Thanks @BillFox , yes I am aware that both built-in and SSO can be enabled at the same time and when that is enabled the UI appears that allows user to pick.
What I am wondering is if there is a way to sign-in as a built-in user without this UI appearing? i don't want to give users the option because when i do, they try to enter their SAML SSO credentials into the ArcGIS login section and that fails. When the built-in option is disabled, the users are immediately signed in via the SSO SAML just when they visit a map or app and don't have to click this experience.
BillFox
you could ArcGIS Server's admin directory like that but as far as I can tell anything portal-ish prompts that dialog
BillFox
highly recommended in case you have any AD issues too
BillFox
