WFS Publishing Error
1366
09-18-2012 06:25 PM
karenvolarich
I've published dozens of services, running the analysis tool via ArcMap.  This is version ArcGIS server and desktop 10.1.  I'm having an issue with a single map service and cannot figure out why I can't see it via the browser.  No errors are thrown during the analysis section and it publishes fine.  It's a generic error...any one have any ideas:
Error: Error handling service request: Cannot obtain a free instance.; nested exception is: com.esri.arcgis.discovery.ejb.ArcGISServerEJBException: com.esri.arcgis.discovery.servicelib.AGSException: AutomationException: 0x80070057 - One or more arguments are invalid
Code: 500
karenvolarich
So as it turned out one of the layers (out 18) had aliases on the fields (not supported by WFS).  Suggestion to esri - at 10.1 the analyze tool should return this as a "HIGH" error - since the entire WFS will then fail.
