In our infrastructure we have two Portal for Arcgis machines in High Availability. We have being monitoring the size of the directory C:\arcgisportal\backup\walarchive.
We have read that webgisdr reduces its size removing database logs. But the point is that after running webgisdr it truns out that the directory has 84 MB in one node and 2gb Gb in the other
Any idea about what is wrong?
Thanks for your help
GD
Unfortunately the DR tool doesn't delete the walarchive logs on the standby machine when it's run at this time. You'll need to delete them manually. We'll correct this in the software.
Jon, has this made it into a release yet?
Yes, this is included in patch:
Portal for ArcGIS High Availability and Disaster Recovery Quality Patch
