Web Adaptor properties file on 10.1 (unix version)
2230
17
10-31-2013 10:25 AM
DaveWeiss
After installing the webadaptor on 10.1 (unix) I have tried to configure it. I get an error that says "Unable to register the GIS Server with the Web Adaptor". Also, there is an error in tomcat saying it was unable to open the web_adaptor.properties file. Where should that file be and what should be in it? Thanks.
JustinRodriguez
Hello again,
My suggestion would be to disconnect the web adaptor from the admin or manager page, and try to register again. Thank you very much-
Justin
DaveWeiss
No luck. I unregistered the web adaptor from the admin page. Then registered it again. If I register it from the admin page I don't get an error. If I register from the webadaptor page I get "Unable to register the GIS server with the Web Adaptor. Please make sure that the GIS server machine is running and that the account specified has administrative privileges to the site."
Though it will show up from the admin site, if I then go to the adaptor config page it still says no GIS servers are registered.
TimJohnston2
Hello Again,
Can you confirm you followed these steps:
Unregistered from the admin/manager endpoint
registered using the web adaptor configuration page (not the admin/manager page)
Justin
DaveWeiss
Yes, I unregistered from the admin page and tried to register from the webadaptor page.
TomRipley
I have the same problem..is there a solution (I have done all the suggestions on this thread)
T
DaveWeiss
T
I never got the linux adaptor to work. You can install a windows web adaptor and point it at the linux server and that works without any problems.
JustinRodriguez
Hello Everyone,
The issue is most likely permissions. It seems that the config cannot update itself for whatever reason. Does your ArcGIS Install user have rights to the directory housing the web adaptor war file? Thanks-
Justin
PaoloCorti
Hello Everyone,
Justin
same problem here, even after giving 777 to the /var/lib/tomcat6/webapps/arcgis directory.
Honestly I have to test this for my company, but I start to be really fad up with this installer process that is totally linux unfriendly.
