Web Adaptor 10.1 on Windows Server 2012
839
05-31-2013 12:01 PM
DougCollins
I have gone through the installation of ArcGIS Server 10.1 SP1 and all seemed to go smoothly.  However now that it is installed I have discovered that the Web Adaptor is installed on port 6080.  I guess this must be a default???
So my Rest services are now showing up on http://servername:6080/arcgis/rest/services
How can I change the port of that Web Adaptor to port 80 so that outside access is available to the rest services?
I am running Windows Server 2012 with ArcGIS Server 10.1 SP1
Charlie
RichardWatson
ArcGIS Server includes a built-in web server which uses port 6080.
You can also install the web adaptor product which I believe defaults to port 80.  Installing the web adaptor does not disable the built-in web server.
http://resources.arcgis.com/en/help/main/10.1/index.html#/About_the_ArcGIS_Web_Adaptor/01540000028p0...
RichardWatson
BubbaHey
Occasional Contributor III
Richard is correct.  If you go to http://localhost/arcgis/rest/services - that is using the Web Adaptor.
DougCollins
After digging a bit deeper it appeared that some of the files for the Web Adapter were missing.  I uninstalled it and re-installed it and now it does work as expected on Port 80.
Thanks for the info and help.
Charlie
