Watch ArcGIS Server directories on a service change
686
11-29-2017 10:29 PM
MarkMindlin
Occasional Contributor III
The main goal is to save a service changes history - like "version control" of map document/service.
We are trying to watch files/folders after a service was published/changed.
What is a file that a setting "maxRecordCount" is stored in? Meaning some place like "arcgisserver\10.3\directories..."
Any help please.
JakeSkinner
Esri Esteemed Contributor
Hi Mark,
The file that records the MaxRecordCount is located in the arcgisserver directory (i.e. C:\arcgisserver).  You will need to dig into this directory further.  Ex:
C:\arcgisserver\directories\arcgissystem\arcgisinput\<service name>.MapServer\extracted
Within the above directory you will see the file serviceconfiguration.json that contains this info.
MarkMindlin
Thanks Jake,
The correct answer (tested on 10.3.1 version) is
arcgisserver\10.3\config-store\services\folderName\<service name>.MapServer\<service name>.MapServer.json
What version do you mean? Have you answered about service change?
