Visible scale range
1427
05-07-2014 10:06 PM
BeraAkamole
Hi
We use Arcgis server to publish services. These services are combined into applications which is used by our organization.
Is it possible to set a visible scale range for a service kind of like the same way as you can set a visible scale range for a layer in the unpublished mxd?
Im thinking of publishing the same map (/service) twice, cache one down to scale 1:2500 and then i want the other one to become active (and the cached one inactive) for scales below 1:2500 and this i want to be dynamic. I dont want to use 'cache on demand'
LuciHawkins
Visible scale ranges that are set for layers in the mxd prior to publishing are honored on the server.  You can also set a minimum or maximum scale range when you load the layer in the javascript application.
https://developers.arcgis.com/javascript/jsapi/layer.html
Hope this helps,
Luci
