user-schema geodatabase deprecation
1429
11
10-16-2023 04:00 AM
coolgis
New Contributor III
Hi
We have Arcgis Enterprise 10.8.1 with Oracle geodatabase.
It has several user-schema geodatabases with existing database users.
I want to move the data from the user-schema geodatabases into the sde geodatabase.
From arcgis pro , I connected to userschema geodatabase as a schema user. and connected to sde schema as a sde user.
Can I copy data from user-schema geodatabases and paste into the sde geodatabase.
Is this process correct?
If I have ABC user with ABC schema. I just copy the data into SDE schema. and then assign the privileges to ABC user?
I find the esri documentation confusing. why esri doesn’t make it clear ?
why there is a need to create a new database user if one already exists ?
If there is no user schema , how do we distinguish between different users or type of data?
How does users access their data only and not being able to edit others data?
Is there any issues with all the users data owned by SDE?
Thanks
coolgis
New Contributor III
Hi @MarceloMarques
Database query and ArcGIS pro screenshots match as yours.
You both are amazing and of great help.
Really appreciated.
Thanks
MarceloMarques
Move user-schema geodatabases to stand-alone geodatabases in Oracle—ArcGIS Pro | Documentation
the documentation mentions 3 options:
1. Move the data from the user-schema geodatabases into the sde geodatabase
2. Move all user-schema and sde geodatabase data to a new geodatabase
3. Move each user-schema geodatabase into its own stand-alone geodatabase
I recommend using the 3rd option and move to an Oracle Container Database and Oracle Pluggable Databases, each Pluggable Database is a Geodatabase.
I hope this clarifies.
| Marcelo Marques | Principal Product Engineer | Esri |
| Cloud & Database Administrator | OCP - Oracle Certified Professional |
I work with Enterprise Geodatabases since 1997.
“ I do not fear computers. I fear the lack of them." Isaac Isimov
