Upgrade Enterprise site with only web adaptor to 10.9.1
1420
12
07-19-2023 09:33 AM
KevinPiraino2
Looking to get some guidance on upgrading an ArcGIS Enterprise site from 10.7.1 to 10.9.1 when the existing site only uses a single web adaptor. As it stands the Portal and Server site both share the same web adaptor (arcgis) and as dictated by ESRI documentation, this isn't supported anymore. My thought was to follow the below workflow to complete this upgrade, but was looking for any additional guidance or advice.
1. Unregister existing web adaptor with ArcGIS Server
2. Upgrade Portal
3. Uninstall/Re-install web adaptor for Portal --> use "arcgis" name
4. Upgrade ArcGIS Server (AGS)
5. Install web adaptor for AGS --> use "server" name
6. Upgrade datastore
MarceloMarques
@KevinPiraino2 - I discussed this with other collegues and the feedback that I got was.
https://enterprise.arcgis.com/en/portal/latest/administer/windows/using-a-reverse-proxy-server-with-...
Question: Does Esri supports to rename the webapators ???
Answer: No, it is not a supported workflow.
Questions: Can Esri Technical Support assist to rename the webadaptors???
Answer: No, it cannot, it is not a supported workflow.
Question: Can Esri Professional Services assist to rename the webadaptors ???
Answer: Yes, Esri Professional Services has tools and methods that can be used to rename the webadaptors, the customer can reach out to Esri Professional Services for assistance.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Certified Professional | "In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 32 years, my passion for GIS has only grown stronger." | “ I do not fear computers. I fear the lack of them." Isaac Isimov |
MarceloMarques
@KevinPiraino2
1. Uninstall the webadpator
2. Upgrade Portal
3. Install the new webadpator for portal https with name "portal" and configure the webadpator
5. Install the new webadaptor for arcgis server https with name "server" and configure the webadaptor
6. upgrade the datastore
Upgrade your ArcGIS Enterprise portal—ArcGIS Enterprise | Documentation for ArcGIS Enterprise
note: look the steps under "Perform an upgrade of your portal deployment"
you will see that it asks to uninstall the webadaptor before doing the portal upgrade and the arcgis server upgrade, follow the same steps.
I hope this helps.
KevinPiraino2
Thank you for the clarification on the order of upgrading each component. One question I had regarding the naming of each web adaptor, currently in the existing Enterprise site, the single web adaptor uses the name "arcgis" (the default name). If I were to change the web adaptor for both Portal and Server to something other than "arcgis" as you suggested, would this not cause issues with the existing services in the deployment?
MarceloMarques
I will research with colleagues.
KevinPiraino2
Thank you for this input. With the change to the new naming pattern for the Web Adaptors, what will happen to the content that is already in Portal site from the existing federated server? As it stands now, those services use the "arcgis" web adaptor name (EX: https://gis.domain.org/arcgis/rest/services/pointsLayer ). Will I need to un-federate & re-federate my AGS with Portal? Will I need to remove and re-add these layers?
MarceloMarques
EricKriener
Hi @MarceloMarques , is removing the webadaptor first still the case?
I have never done it that way before...in fact, your latest doc has it in the order that I've always done it...
https://enterprise.arcgis.com/en/portal/latest/install/windows/upgrade-portal-for-arcgis.htm#ESRI_SE...
Section #9 (AFTER the portal upgrade)
Asking b/c I had problems with the webadaptor on two separate machines, one portal and one server, last night trying to upgrade to 11.2 and had to roll back to snapshots.
thanks.
MarceloMarques
@EricKriener - the 11.2 documentation says that you can uninstall / install the Web Adaptor after the Portal Upgrade and after the Server upgrade. I have always done in this order as well and I have never run into any issues.
Upgrade Portal for ArcGIS—ArcGIS Enterprise | Documentation for ArcGIS Enterprise
EricKriener
no, it doesn't @MarceloMarques ...did you read the link I sent?
MarceloMarques
@EricKriener - it seems that the 11.2 doc was rectified, previous versions 11.1, 11.0 of the documentation we were left with the impression that we had to uninstall the web adaptor first and then perform the upgrade, I personally had always uninstalled / installed the Web Adaptor after the upgrade and I never had issues.
