Update ArcGIS Enterprise license
236
05-14-2021 01:09 PM
UalasRohrer
Hello, I have a Highly Available ArcGIS Enterprise stack deployed with ArcGIS Enterprise Cloud Builder for AWS. I am wondering how can I update the licenses for the portal, server, datastore, and webadaptor?
Thank you!
Ualas
ReeseFacendini
The licenses for Portal for ArcGIS can be updated through the Portal UI, ArcGIS Server is updated through the licensing wizard on the machine, ArcGIS DataStore is updated through a command line tool also on the machine, and ArcGIS Web Adaptors don't have a license associated with them.
Portal:
  • Sign in to home page with an admin account
  • Select "Organization" from menu at the top of the window
  • In the blue bar, select "Licenses"
  • Upper left-hand side select "Import licenses"
Server:
  • Log into the machines where ArcGIS Server is installed
  • From the Start menu, open "Software Authorization for ArcGIS Server"
  • Enter the new ECP code, or upload the .prvc file downloaded from MyEsri
  • Follow the prompts until the wizard succeeds and closes
  • Repeat for the additional ArcGIS Servers in the HA setup
DataStore:
  • Sign into the machine where DataStore is installed
  • Open Command Prompt as an admin, and navigate to the <ArcGIS Data Store installation directory>\datastore\tools directory (i.e. C:\Program Files\ArcGIS\datastore\tools)
  • run the tool "updatelicense" (there are no additional parameters needed)
  • Repeat for all other DataStore installations
https://enterprise.arcgis.com/en/data-store/latest/install/windows/data-store-utility-reference.htm#...
ReeseFacendini
Portal:
Server:
DataStore:
UalasRohrer
Thank you for the reply. I'll try the solution on Thursday and I'll provide feedback.
UalasRohrer
Hi @ReeseFacendini , your instructions worked great. Thank you!
