Understanding the effects of domain name change
1906
06-08-2023 10:18 AM
wizgis
Our system will be going through the process of a domain name change because of which the machine on which our arcgis enterprise is installed is going to be moved to a different domain name.
I just want to understand what would be the implications of it.
Additionally, I came across a similar post: https://community.esri.com/t5/arcgis-enterprise-questions/reconfiguring-arcgis-enterprise-after-mach...   however, it has been mentioned to do a fresh install of the software. If we do a fresh install of the software what would happen to existing services, and applications.
Any insights on this would be helpful.
A_Wyn_Jones
You need to backup your content before the change in name happens - Esri provide self contained backup tools that can help with this. WebGISDr can migrate the content in this instance but please be aware of whats in a WebGISDr backup. I.e. Tile caches are not included.
https://enterprise.arcgis.com/en/portal/latest/administer/windows/create-web-gis-backup.htm
https://enterprise.arcgis.com/en/portal/latest/administer/linux/overview-backup-restore-web-gis.htm
Once name change has happened, reinstall the same version of Enterprise.
"We've boosted the Anti-Mass Spectrometer to 105 percent. Bit of a gamble, but we need the extra resolution."
A_Wyn_Jones
wizgis
Thank you @A_Wyn_Jones  for sharing this with me. I will definitely check these links out.
wizgis
@A_Wyn_Jones  Currently, we are on ArcGIS Enterprise 10.9.1 and was wondering if we take a backup and then after domain name change we install ArcGIS Enterprise 11.1. Would the restore work or first will have to re-install 10.9.1 do the restore process and then upgrade to 11.1
A_Wyn_Jones
You will have to install 10.9.1, restore and then upgrade.
Hope this helps!
wizgis
@A_Wyn_Jones Thank you for sharing this. This surely helps.
