Unable to open the ArcGIS Sever Manager ???http://localhost:6080/arcgis/manager???
24906
12
10-12-2013 12:33 PM
JamalNUMAN
Legendary Contributor
Unable to open the ArcGIS Sever Manager �??http://localhost:6080/arcgis/manager�?�
The url http://localhost:6080/arcgis/manager fails.
[ATTACH=CONFIG]28288[/ATTACH]
What might be the issue here?
I replaced the �??localhost�?� with the name of the machine but didn�??t work neither.
Thank you
Best
Jamal
Jamal Numan
JamalNUMAN
I’m facing the same issue in 10.6.1, the manager fails to start!
What could be the issue here?
Jamal Numan
MajdoleenO_A__Awadallah
You need to make sure that the Arcgis server service is running, if not please try to start it. Otherwise, you need to go to the properties of the service change the user account to ./Arcgis and type its password. Kindly find the screenshots below:
JamalNUMAN
Many thanks Majdoleen for the help.
Have you figured out why the ArcGIS Server has been installed having its Windows service turned off?
Jamal Numan
