unable to connect to arcgis server
2899
08-22-2014 03:10 AM
jayasudha
Hi
I am able to login arcgis server 10.1 through web based server manager as admin user. If i use same credentials to connect from arcgis desktop 10.1 (catalog), there is error: No resource could be found at that address.
server URL http://xyz.pq.mn.bb:6080/arcgiswebadaptor/admin
server type: arcgis server
please help me
JakeSkinner
Esri Esteemed Contributor
When you install the web adaptor, this gives you the ability to connect to ArcGIS Server without having to specify the port number, 6080.  The name of the ArcGIS Server instance, arcgis, will not change.
Connecting w/o web adaptor:
http://xyz.pq.mn.bb:6080/arcgis/admin
Connecting with web adaptor:
http://xyz.pq.mn.bb/arcgis/admin
JakeSkinner
Hi Jaya,
Did you name the ArcGIS Server instance 'arcgiswebadaptor'?  Try the following instead:
jayasudha
Hi Jake
Thanks for your help.
When I changed the URL as mentioned by you, it works fine.
In fact, arcgiswebadapter is also installed and i used to connect earlier with the URL mentioned in my first post.
Today i faced this problem. Please suggest me is there any problem in connecting through arcgiswebconnector.
regards
JakeSkinner
jayasudha
Thanks Jake
