The web application can???t be accessed from other machine,
7159
16
05-26-2013 10:00 AM
JamalNUMAN
Legendary Contributor
The web application can�??t be accessed from other machine,
I have 3 machines connected by switch. The service is published on �??Jamal-pc�?�. I could access it by:
http://jamal-pc/apps/T5
[ATTACH=CONFIG]24690[/ATTACH]
I tried to access this application (http://jamal-pc/apps/T5) from �??mira-pc�?� but sounds that the web application ends up with nothing
[ATTACH=CONFIG]24691[/ATTACH]
What might be the issue here?
Thank you
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
Refresh the page bypassing the browser cache:
http://en.wikipedia.org/wiki/Wikipedia:Bypass_your_cache
Many thanks Richard for the prompt help,
I tried bypassing the browser cache of IE, Firefox and Google chrome but still the Silverlight isn�??t able to display the maps.
What other options may I still have?
RichardWatson
Clear your browser cache, capture the session in Fiddler, and then post the Fiddler session.  If you can't post the session to the forum then post it cloud storage, e.g. DropBox, SkyDrive, etc., and post the link here.
by Anonymous User
Not applicable
Very much appreciated Richard for the help,
I could figure it out now with fiddler! The issue is related to the source of the service.
The url of the services is set to be:
http://localhost:6080/arcgis/rest/services//T5/MapServer
and thus as the client starts:
http://jamal-pc/Apps/T5/
the Silverlight does start but with no data (service) as it will look for the data from his/her machine (localhost).
[ATTACH=CONFIG]24719[/ATTACH]
The issue now is how the services (url) in the silverlight web application can be re-directed
to:
http://Jamal-pc:6080/arcgis/rest/services//T5/MapServer
[ATTACH=CONFIG]24720[/ATTACH], [ATTACH=CONFIG]24721[/ATTACH]
RichardWatson
I am glad that you have made some progress.
Unfortunately, I have not used the Silverlight viewer application so I cannot speak to how it works.  It seems to be some type of configuration issue but I know that you already know that:)
Perhaps someone in the ArcGIS for Viewer Silverlight forum can help you.
by Anonymous User
Not applicable
Many thanks Richard. Your help is behind the progress that took place.
Hope an expert can advise in how to re-direct the service url or otherwise I�??ll be creating it again from scratch
Best
Jamal
AlexeyTereshenkov
Jamal, you can update the URLs used for your services by editing a Map.xml file in any text editor. This file is located in the C:\inetpub\wwwroot\Apps\%AppName%\Config when using the default folder. I am sure you will find out where it is if you are using a non-default path. Just run find and replace in the text editor to change the localhost for the PC name, restart web browser and clear its cache and you should be good to go.
by Anonymous User
Not applicable
Man thanks Alexey for the answer. This is very helpful
Best
Jamal
