System Test for Web Download
1291
08-21-2023 01:33 PM
DevinBartley2
I am looking for the download link to the System Test for Web tool referenced in the "ESRI Best Practices: Tunin, Testing, and Monitoring" presentaiton.
I found this previous post which was solved but the link provided there has since broken
Solved: System Test for Web - Esri Community
Has the tool been deprecated? I see other more current articles that suggest you use Apache JMeter.
David_McRitchie
Hey Devin,
I believe this will have been depreciated. From the other community post you linked I checked through the 2nd link and found the email for the publishing account is SystemDesigner@esri.com. I think it would be best if you contacted them.
Hope that helps,
David
Esri UK -Technical Support Analyst
TonyContreras_Frisco_TX
Refer to this post for the GIS Enterprise reporter, a product from someone on the Esri Professional Services team. This might provide the functionality you are looking for.
dgiersz_cuyahoga
You may also want to check out the resources at https://trust.arcgis.com/
There is a 'Security Advisor' tool available that is useful.
#CLE #sloth
AndreaB_
I was looking for it also. It must be gone. Did you email that SystemDesigner@esri.com ?
