It's possible on AGOL Survey123 to export a report using a template doc (the documentation calls this printing instead of exporting). Regarding similar functionality with Enterprise --
This print report feature is not there with 11.2. Is my understanding correct that it is there with 11.5 but only if your Enterprise deployment is public facing (i.e., accessible from the public internet)? This is my source of that understanding.
That's quite a limitation; is there not a firewall configuration for a workaround?
Will this be true of Enterprise 11.6?
You can generate Survey123 report on 11.2 also, but will have to make your Portal public facing.
There will be no 11.6. Next release is 12.
