Hi. I have just set up a new ArcGIS Enterprise and Portal.
What I would like to do is integrate portal with my previous, non-GIS, system that was based around SQL.
Is there a way to view, and ideally manipulate, my tables in SQL from within portal and by extension ArcGIS Pro?
I have successfully connected the SQL database and enabled the geodatabase in ArcMap.
Thanks
ArcGIS Server/Enterprise 10.7.1
It appears that the Server is built on a PostgreSQL database.
