I am getting the following error when trying to register my database with my server.
Machine: <machine name> [<databasename>: (null)]
ArcGIS 10.3
SQL Server 2012
Database authentication
I have tried to change PostgreSQL version to 9.0.5 and the same error remains. Do you know any other cause?
Hi Experts
I'm also facing the same issue in registering the database before publish and i tried above stated workflows but i received below attached error in the screenshot , I tried using both database platform(Oracle 11g , client 32 , sql server 2012 ) with arcgis 10.4 to test but failed ..
It works fine with me (ArcGIS 10.7.1 with SQL Server 2019)
