Questions about updating SSL certificates on 10.8.1
6111
18
11-10-2022 09:17 AM
LLCCG
IT tells me that our SSL certificate is expiring soon and needs to be updated.
I have a HA system with Portal, Server, and Data Store each running on two machines.
I'm not really sure how many places I need to update these certificates, though.
In Portal Admin, when I go to Home > Machine > MachineName > SSLCertificates, each of the two certificates listed shows an expiration date of 2053. I'm assuming I don't need to update anything there.
In Server Admin, when I go to Home > Machine > MachineName > SSLCertificates, I have one that expires soon, and and a self-signed certificate that expires in 2053.
Is there any way to check the expiration date of the certificate for Data Store?
Is there any other place I need to check for certificates that expire soon?
I'm thinking that all I need to do is update the one in Server Admin that is expiring soon, and restart services, right?
Thanks!
Scott_Tansley
MVP Regular Contributor
Cool - you'd be surprised how many people install a cert but then leave that option as self-signed.  So now you need to import your new certificate:
https://enterprise.arcgis.com/en/server/latest/administer/windows/configuring-https-using-an-existin...
into the first screen that you sent a screen grab off, and then update the entry above.  Test, then delete the old cert.
I'm risk averse, so take a snapshot of the machine before you do it.
Scott Tansley
https://www.linkedin.com/in/scotttansley/
BillFox
MVP Notable Contributor
do the 2053 dates correspond to self signed certificates?
LLCCG
Yes
Scott_Tansley
In many builds, it's just the Web Adaptors (IIS - for example) where certificates need to be replaced.  It is obviously possible to install certs in the application components, but many organisations do not.
Scott Tansley
LLCCG
I see the one in Server Admin that is expiring soon. That one must have been installed in ArcGIS Server, right? Or is it just reading it from IIS?
Scott_Tansley
How do you access server manager? 6443 addresss?  Alias name?  Where are you looking at the date?
Scott Tansley
LLCCG
Yes, using the 6443 address. The date isn't in Server Manager, though, it's in Server Admin (server.domain.com:6443/arcgis/admin). It's under Home>Machines>MachineName>sslcertificates. When I open the two certificates listed, on is a self-signed certificate that expires in 2053, and the other expires in 2022.
Scott_Tansley
Ok.  We may need some screen grabs here.  Normally there will only be a self-signed cert there with a long date.  But having a short date suggests a cert was installed.  But, you would normally also install intermediate and root certs as well, so I would have expected 4 certs not 2.  On one of the pages in server admin it will state which cert is in use.  You may have imported a cert, but could still be using self-signed. So you may need to share some details?
Scott Tansley
LLCCG
Here's the screenshot from Server Admin that lists the certificates. There is an identical page for the other machine on which Portal, Server, and Data Store are installed. The one ending in "2022" is the one that expires soon. In Server Admin, when I go to the "Machine" page and click on each machine, it says that the Web Server SSL Certificate is that cert ending in 2022.
Scott_Tansley
Awesome and thanks for commenting out the detailes - really good practice.  So now I can see which certs are installed, and that's what I expected.
When you navigated through to that page, I now need to see the page before.  You will have had a screen like this:
To get to the screen you shared you would have clicked on the green highlighted sslcertificates link.  I now need to know what is in the yellow highlighted Web server SSL Certificate parameter.
This will tell me which one of those two certificates is in use.
Scott Tansley
