Publish "dimension feature class" to Feature Layer
1437
04-08-2022 06:11 AM
LouiePang
Hi All,
By ref to the link: https://pro.arcgis.com/en/pro-app/latest/help/data/dimensions/create-a-dimension-feature-class.htm
I did can successfully create the dimension feature. May I know if the created data can be publish to ArcGIS server, e.g. as a feature layer that for viewing in Web?
I think view only will be good but if any JS API can allow to edit / create will be the a bonus for me then.
See if any experience can be share, thanks.
TanuHoque
@LouiePang
You should be able to publish as a map service on your ArcGIS Server, and consume that as a map image layer in your webmap/app.
But I doubt if you can add that as a feature layer in your app and do edits.
LouiePang
Thx, image layer did work, we exploring if any other way to create new record e.g. SOE may be
