Publish image service from mosaic with infrared band
2492
12-11-2014 02:32 PM
BlakeTerhune
MVP Frequent Contributor
I have a mosaic dataset with tiled imagery that has an infrared band. How can I publish an image service on ArcGIS Server 10.2.2 so the published image uses the correct bands to display it as infrared instead of just regular RGB? Previously we published it as a map service but I'd like to do it as an image service if possible.
HayleighFisher
Hi, we are trying to do something similar to this, did you ever find a solution? I realize this was about 6 years ago so not sure if this is still active. Thanks!
